1996 Ford Contour
acxz's Avatar
09-13-02, 11:44 AM   #1
acxz
1996 Ford Contour
I got this car about two month ago, it my first car. It's zetech, 2.0 L, 4 C, and DOHC. It's only has 28,000 miles on it. At idle when the car is in drive and feet is on brake the car is shaking too much. Does anyone know what it might be?
Jackofalltradez's Avatar
09-13-02, 02:10 PM   #2
28K? U got a gem!
Mine is 96, ZTec just like yours. I noticed the same thing with the idle - it's inherent in the 4cyl versions of this car.
Just make sure or check that your air & fuel filters, Mass Air Flow sensor, and injectors are all clean. Beyond that - just live with it - or trade it in for a V6 Contour!
Also, how is pickup with car? If it is very responsive then we can rule out bad sparkplug wires or misfiring.
-JackOfAllTradez
acxz's Avatar
09-13-02, 04:17 PM   #3
acxz
The car runs pretty good except it shakes. We put in new sparkplug and new sparkplug wires, checked Mass Air Flow sensor. Everything looks just like new. Somehow, it just shakes. Don't know why--or maybe that's why it only got 28k miles on it.
Joe_F's Avatar
09-13-02, 08:07 PM   #4
Joe_F
Start with the links and posts in my signature file.
scott spa's Avatar
09-16-02, 08:25 AM   #5
scott spa
1996 contour
Ford had alot of problems with shaking and vibs on early contours look At tsbs and you will fine that most talk about hoses and cables hitting each other and body parts, PS check that the raditor is not touching the body medal to medal. hope this helps.
