Transmission Ticking Sound
Old 09-15-02, 10:22 AM
0-60in5
Car: 1992 Pathfinder, Auto Transmission, 150,000 miles, no prior tranny problems.
Problem: when the engine revs between 3 and 4 thousand rpms, there is a distinct ticking sound that I believe to be coming from the transmission, this happens regardless of the engine temperature, however it seems to be louder when the engine is under strain, (going up a hill, etc.)...it happens in every gear, as well as if i rev it up in neutral, however it seems quiter in that case. Any thoughts on what this could be?
Thanks.
Old 09-15-02, 02:10 PM
Joe_F
Sure it's tranny related? Might be pinging from a stuffed EGR valve or an exhaust leak.
Does the tranny slip during this troubled time?
Old 09-15-02, 02:21 PM
0-60in5
I'm not possitive that its the tranny, it was just an assumption I made based on the symptoms of the problem, the tranny does slip occasionally but it has yet to happen in coherence with the noise.
