turbo probe
Old 09-16-02, 09:44 AM
kingshab
turbo probe
are the heads the same for a non turbo as for a turbo or am i going to have to find a 2.2 turbo engine to get head from
Old 09-16-02, 09:53 AM
Joe_F
Please use your reply button to keep all posts on the same vehicle together for clarity.
The head likely differs between the turbo and non turbo. There are places that sell remanned heads. Or you can simply take yours off and have a machine shop go through it. It should have been done with the head gasket repair.
Chances are if the engine cooked that bad it cracked the head or may have ruined the bottom end. Sounds like hydrolock if it's spitting water out of the tailpipe like that.
Old 09-16-02, 09:58 AM
kingshab
hydrolock
what is it and how to check bottom end
Old 09-16-02, 10:48 AM
Joe_F
Hydrolock is when you are compressing water, which is not a good thing. It can bend a connecting rod.
If the gasket blew, it probably poisoned the bottom end with crap and junk.
Does the engine crank freely?
Old 09-16-02, 01:03 PM
kingshab
hydrolock
yes it cranks when key is turned no funney noises from engine just water out of exhaust and will not fire
Old 09-16-02, 01:10 PM
Joe_F
Does it have any spark? Is it physically shooting water (or is it coolant) out of the tailpipe?
It sounds like a bad ring and/or valve if it's shooting crap out of the tailpipe.
Old 09-16-02, 01:12 PM
kingshab
hydrolock
not shooting but is some water coming out of tailpipe yes there is a spark not a bright blue but is a good spark not alot of water and is not coolant
Old 09-17-02, 09:34 AM
Joe_F
What's the fuel pressure? Rent a gauge from any Autozone and see if there is pressure at the test port.
