'98 Cavalier
Old 09-17-02, 04:33 PM
gowitheflow
'98 Cavalier
I have a '98 Cavalier that will start but after it idles for a few minutes it begins to run rough and then shuts off. If I try to pull out it hesitates and stalls ; every time. It's a 4 cyl. F/ I , automatic trans. Thanks for your input.
Gerald
Old 09-17-02, 04:42 PM
TECHMAN
Need to Scan veh. for codes, also check to see if E.G.R. valve is opening up to soon causing it to stall, unplug valve and see if it fixes pro. May need to check fuel presure with gauge. Get back with findings. GOod Luck---------Dave---------
Old 09-17-02, 05:31 PM
kaybyrd's Avatar
I had an 89 that did the same thing. The throttle body gasket was leaking and it was gulping air. Do you smell gas? If not, it may be something else.
Kay
Old 09-17-02, 05:45 PM
Has the fuel filter ever been changed?You need to check basic stuff like air ,fuel filters,leaking vacuum hoses,plugs and wires before you dig into big money parts,like sensors.Even maybe throw some fuel injection cleaner in the tank.You may be suprised.Maintenance is the key,most companies tout maintenance free vehicles,it just isn't so.
