Starting Car All The Time
Old 09-25-02, 10:10 AM
K
kdlady
THE 88' DYNASTY LE -STARTS SOMETIMES AND BARELY TURNS OTHER TIMES-I CHANGED THE BATTERY CABLES WHICH WERE BADLY CRACKED-AND REPLACED THE OLD BATTERY-I AM STILL HAVING A PROBLEM STARTING THE CAR ALL THE TIME-NOW THAT I'VE REPLACED THE BATTERY/CABES IT STARTS BUT AFTER 3-6 TRIES
Old 09-25-02, 11:41 AM
Please don't type in all caps, essentially it means you are yelling.
When you say that it starts after 3-5 trys....is it cranking normal, and just wont start. Does it sound like the starter is turning at normal speed, or does it sound like it is cranking slow? If it is cranking normal speed, but just won't start for 3 times or so, you might have probs other than the starting system.
Old 09-25-02, 11:52 AM
K
kdlady
Sorry, It cranks partially. First, it clicks several times than partially cranks or turns -maybe 1 or 2 x then it starts after several tries
Old 09-25-02, 03:09 PM
Joe_F
If you've verified that the cables are good and the connections are good, have the starter tested.
