Ford Festiva Rear Glass
NOVASS's Avatar
09-25-02, 04:21 PM   #1
NOVASS
Is there any particular trick to replacing the rear window (back lite) in a Ford Festiva? The rubber gasket seems to be okay.
knuckles's Avatar
09-25-02, 10:40 PM   #2
knuckles
The trick to installing gasketed glass in to slip a string into the gasket channel & gently pull the string as a helper pushes on the outside of the glass. This is easy if you've done it before, not so easy if you've never done it or never seen it done.
Your best bet would probably be to take it to a glass shop & let them install it. It might be the best $ you ever spent.
Joe_F's Avatar
09-26-02, 07:30 AM   #3
Joe_F
I agree with Knuckles.
