My 1995 ford explorers transmission or something is messed up it is an automatic with overdrive , you can start the engine put it in reverse and it will move ok , put in drive , second or first it will kill the engine??? Thanks in advance for any information at all...Read More
I have a '95 chevy lumina sedan with automatic doorlocks. When you activate the driver side power door-lock switch, all doors should lock. The passenger side door-lock would not lock when the switch was pushed and now the driver side door-lock will not lock with the switch. I took the door panel off of the driver side. I reached up and put a little pressure on the rod coming from the outside keylock mechanism and pushed the switch and the switch would lock and unlock the door but when I released the rod, it wouldn't work. I think the problem is the same on the passenger side. The rod has a lot of slop & it seems if I pull the rod towards the driver side seat, it works. But if I move the rod in any other direction, it doesn't work. I need some advice please! I don't know if there is a way to tighten the rod or if I have to replace the whole system. Any advice would be helpful! Also, I was told by my fiance that the door will sometimes not unlock with the key. thanks!!!!Read More
