Air Conditioner Leaking
Old 09-30-02, 09:18 AM
Mare40
My 1995 Mercury Mystique has an air conditioning leak of some sort. When I use the air conditioner, it leaks water inside the passenger floor boards. I assume there is some sort of drain that causing this. Do you have any idea how I can correct the problem myself?
Old 09-30-02, 01:27 PM
This is a common problem where the drain hole gets plugged and the condensation has nowhere to go. This drain is typically accessible under the hood, against the firewall beneath the heater core/evaporator assmbly. Run a wire through it to poke a hole through the crud that's collected to get the drain working again.
Old 09-30-02, 02:32 PM
Joe_F
Thumbs up
I agree. This is your problem.
