1989 Camaro, 305 TBI, Vin E..........Transmission Question
Old 10-01-02, 08:59 PM
Question 1989 Camaro, 305 TBI, Vin E..........Transmission Question
Aloha,
In the morning when the car is cold, my transmission lingers in third gear - it takes high RPM to kick into overdrive. What could be causing this, and can you recommend a course of action for this problem? BTW - when the car is warm, the shifting is on time, and not a problem.
Maitai
Old 10-01-02, 09:02 PM
Joe_F
Change the fluid and filter. Barring that helping, likely internal failure.
Old 10-01-02, 09:27 PM
Change fluid?
Joe,
Do I have to have all the fluid extracted, or just change out what is lost during the removal of the pan?
Maitai
Old 10-02-02, 03:37 AM
Joe_F
Drop the pan and change the fluid and filter. You could also alternatively , take the lines off the radiator and use the vehicle to pump out the fluid by starting it. Not really a great idea (running it low and dry) but it "works".
I'd drop the pan and change the fluid and filter if it were me. If that doesn't help, likely internal failure of the tranny. Rebuild time
Old 10-02-02, 12:16 PM
Thanks Joe!!!
