Isuzu pickup A/C
Isuzu pickup A/C
My Isuzu pickup is making a squeling noise from the a/c belt. I have replaced the belt and the bearing in the idle pulley. Have adjusted the belt from loose to tight. Only does it over 3,000 rpm and not all the time. Also the a/c is draining into the pass. side. I cleaned the tube out but no help. Is there a way to reseal it without removing the eavp. core? Hope you can help. Thanks.
