Braking Problem
Old 10-04-02, 01:18 PM
Braking Problem
Hi Joe,
This is on my 1989 Camaro, Vin E, 305 TBI.
I have replaced all front end components. That is:
Inner and outer tie rods
Control arm Bushings
Ball Joints
Idler Arm
Struts and upper strut bearing/housings
End link bushings/stabilizer bar bushings
I also replaced:
Inner and outer wheel bearings
brake pads
cut rotors
Did complete front end alignment
However, when I stab the brakes/lean on them heavy, I sometimes get a violent pull to the right..........what could be the cause of this?
Thank you,
Maitai
Old 10-04-02, 01:50 PM
Joe_F
You have a stuck caliper or a clogged rubber brake hose.
Change both brake hoses and rebleed the system. If that doesn't help, change both calipers.
The brake hoses rot from the inside out and act as check valves when they go bad. Very common.
The hoses are a few dollars and in stock at any parts store.
Old 10-05-02, 01:36 AM
Thanks.....
Thanks Joe,
Will do and report back for the benefit of everyone here. Thanks again for all your help.
Maitai
Old 10-05-02, 06:58 AM
Joe_F
Ok and let us know.
Old 12-07-02, 02:05 PM
Talking Ah, feel much better............
Joe,
Well, I finally got to replacing those brake hoses..............She brakes like a champ now - no pulling whatsoever. Thanks for the help, and I help this helps others..........
Merry Christmas
Maitai
Old 12-07-02, 02:13 PM
Joe_F
Thumbs up
No problem and good job!
