Leaking anti freeze
Old 10-04-02, 05:40 PM
L
lteng75
Leaking anti freeze
I have a 1996 Plymouth Voyager with a 3.0 liter motor with a/c. I have started to leak anti freeze and have traced it to trhe freeze plug on the passenger side of the engine, above right above the oil pan towards the front of the engine.
My question is with 76,000 miles on it should I replace it and can I do it myself, if so is this a easy job and does it require any special tools.
Old 10-05-02, 07:38 AM
Joe_F
If you can't see it, leave it to a pro to fix. More aggravation on your part.
If you can see it, it can be removed and replaced with a new one.
Old 10-05-02, 08:06 AM
D
Are you sure it's the plug?Thats were there water pump leaks on those engines.
