Seized brake discs
Rapacious's Avatar
10-06-02, 01:36 PM   #1
Rapacious
Seized brake discs
Is there a easier way than WD40 and hammer to unseize a brake disc from a hub?
dirty dan's Avatar
LA
10-06-02, 02:01 PM   #2
Have you opened the bleed valve on the caliper? (don't let brake fluid get on your paint)
You may try to place a pry bar between the edge of the rotor and the calipers.
michaelshortt's Avatar
WA
10-06-02, 06:45 PM   #3
I use a little heat from a propane torch. Heat the drum or rotor around the area that it fits on th hub. Use a little force at the same time. Sometomes hitting the axle hub during heating the drum or rotor will pop it loose. I almost have at least one that will be stuck. Good luck.
Mike
Retired Real Estate Broker
Home Remodeler
Do it Yourselfer
