700R4 Transmission
CC1736's Avatar
10-08-02, 10:16 PM   #1
CC1736
700R4 Transmission
I have changed two Trans. on my 1988 G-20 Van after about three days they both have loose the drive. They only go into first and second gear. When they shift up any further motor just screams what could be wrong Trans Bad two in a row ?
Joe_F's Avatar
10-09-02, 03:50 AM   #2
Joe_F
Were the trannies used or rebuilt? Rebuilt by the same person?
Early (pre 1989) 700R4's have weak pumps and puke out easily.
davo's Avatar
10-09-02, 04:14 PM   #3
Are you replacing the torque converter and flushing the lines and trans cooler also?If not you may have stored metal debris causing repeat failures.
