88 chev celeb wagon 2.8 fuel pump fuse
Old 10-13-02, 02:21 PM
Cany anyone tell me where the fuel pump/computer fuse is? In my haynes it says it is on the firewall and shows a pic of it..But it isnt there. Haynes indicates the fuse controls both the pump and the ECC and the pump does not make any noise when the key is turned on, plus i do not get any ignition spark at the plugs. The pump was quite loud before when it was "working".
Old 10-13-02, 04:25 PM
Joe_F
Should be in the fuse box and marked ECM or something similar. The owner's manual or the fuse box cover should detail which is which.
Old 10-14-02, 11:00 AM
Dan Meyer
One of my neighbor's cars is a '87 Celebrity. The fuse box is located just under the instrument panel to the right of the steering column. It has a flip down door. Perhaps it's in the same place on an '88. Should be easy to see once you get your head under and look up.
