Heater for 1990 Toyota Camry
toajr's Avatar
10-14-02, 11:11 AM   #1
toajr
Heater Qestion # 2 for 1990 Toyota Camry
I've have no heat however the air does work well. I've checked the heater hoses along the firewall into the car. They do get warm / hot. The Temperature cable to valve along the firewall also operates correctly. Where is the Vent door located inside the car? Is this also attached to the thermostat cable assembly. How can I check to see if this operating correctly. TOA
Joe_F's Avatar
10-14-02, 11:36 AM   #2
Joe_F
Have you flushed the cooling system and changed the thermostat?
Warm up the car. Feel both heater hoses going to the firewall. If they are hot, then the problem is the vent door inside the car. If not, the thermostat is the first thing to change.
