Heater Qestion # 2 for 1990 Toyota Camry
Old 10-15-02, 11:30 AM
toajr
I've have no heat however the air does work well. I've checked the heater hoses along the firewall into the car. They do get warm / hot. The Temperature cable to valve along the firewall also operates correctly. Where is the Vent door located inside the car? Is this also attached to the thermostat cable assembly. How can I check to see if this operating correctly. TOA
Old 10-15-02, 12:30 PM
Joe_F
You have to locate the cable that goes from the HVAC (AC and heat) controller to the vent door). That is hanging up or the door is not closing properly.
