transmission problem
jamesfporter's Avatar
10-18-02, 03:38 PM   #1
jamesfporter
1994 chevy lumina van, 3800 v6 automatic with overdrive. About 5 weeks ago I first notice that when you accelerting or braking the van has no power or would jerk. This is a intermitting problem. Two weeks ago the fluid, filter, and gasket was changed by at a garage. That didn't fix the problem. Took it to a chevy dealership and they inform me that the transmission valves was sticking causing it not to shift properly. Dealer don't work on transmissions. Is there a additive that would work or what is the best way to get it fix?
Joe_F's Avatar
10-18-02, 04:05 PM   #2
Joe_F
The dealer doesn't work on transmissions? That's a first .
Try another Chevy dealer. Likely stuck shift solenoids or torque converter clutch solenoids.
davo's Avatar
10-18-02, 05:52 PM   #3
Are you sure its trans related?I get people with misfires thinking the same thing.What services have been done recently?I agree with Joe a dealer that doesn't do tranny work kinda scary.I could change all of your solenoids in 1 and 1/2 hours.Did they report any trouble codes?
