mercury villager dash lights
I have a 1997 Villager that the instrument lights are not all working .
The left corner is out and also the PRNDL light is out...Any suggestions on how to fix this problem?
I hope this is not a "Dealer Repair".
Please help!!
Please help!!
Likely burned out bulbs from behind.
If you can reach up there and feel the sockets, then go ahead and change them. If not, the cluster might have to come out to access the bulbs....could be quite involved. Might be cheaper to have a shop handle it.
Check the autolibrary.org link I have below and see if that has anything on how the cluster comes apart.
Are you positive no one has accidentally turned the lamp dimmer switch down to low?
Previous Thread
Next Thread
