power steering leak
kncshn's Avatar
10-19-02, 06:20 PM   #1
kncshn
power steering leak
My son's 91 Ponitac GP with 3.1 V6 (130K miles) is leaking power steering fluid. Do i fix it or get a new one? (the pump, not the car!) How hard is this job? i have done brakes, starters, water pumps, etc., but not much lately.
otter_'s Avatar
10-19-02, 06:37 PM   #2
otter_
if it's the pump
that's leaking, replace it. Are you sure that it's the pump that's leaking rather than a pressure hose or the rack itself?
kncshn's Avatar
10-21-02, 05:48 AM   #3
kncshn
am trying some stop leak. i believe the pump is leaking. car has 172K miles, not 130K. (car has been away with son at college) What is a rack?
kncshn's Avatar
10-21-02, 05:49 AM   #4
kncshn
oops, rack is part of rack and pinion,, duh.
Joe_F's Avatar
10-21-02, 06:03 AM   #5
Joe_F
I suggest he have the car checked out professionally. It could be a leaking rack and pinion or a pressure or return line or the pump itself.
Will be tough to pinpoint without seeing the car.
otter_'s Avatar
10-21-02, 08:18 PM   #6
otter_
if it's the pump,
but unless you've done it before, I'd leave it to a pro. Not too much room to work around that 3.1. Stop leak only works for so long and I would wager that it's not too good for the seals in the rest of the system.
kncshn's Avatar
10-22-02, 06:12 AM   #7
kncshn
roger, going to the shop soon. Thanks for the help!
