window attachment
Old 10-20-02, 03:46 PM
joe breckenridge
window attachment
90 honda prelude
hey what kind of adheisive do you use to attach the window to the pieces (plastic to glass at the bottom of the window glass inside the door) that then are screwed to the window mechanisim ---these have come off and I have put them back on twice but they have since come off again --there is a black spongy material on the window glass whrer these attach ,slide into the plastic- but they don't seem to hold the glass tight enough anymore
thanks ,
Joe
Old 10-20-02, 07:20 PM
bigpoppax2
The black stuff you are refering to is possably the stuff they use to seal windshields when installed. I'm actualy unsure of which window you are refering to, but if the parts in question don't need to ever come apart you could use a two part epoxy. You may need to scratch up the glass a bit to get the epoxy to hold well.
Old 10-20-02, 08:23 PM
Joe_F
Rare that this happens.
Take the window to a reputable glass shop. They will bond it for you. Special adhesive used in most cases. Don't fool around.
You can then reinstall the glued/fixed window.
