blower motor
Old 10-22-02, 07:59 PM
C
cjherle
blower motor
My blower motor only works on high setting. Its a 96 plymouth voyager. Any ideas?
Old 10-22-02, 08:22 PM
B
bigpoppax2
You need to replace your resistor block. Typically your heater will only work on one or two settings if your resistor block is shot.
A junkyard will net you one for around five bucks, one for a Isuzu Rodeo from Isuzu was 37 dollars, junkyard $5. Works like a charm.
It is usually mounted in the passenger side under the dash, you may have to drop your glove box to get to it. It's a couple of screws and a plug, might take five-ten mins. to fix. Once you find it that is.
