90 Ranger, need help
Old 10-23-02, 06:30 AM
K
Kynative
Question 90 Ranger, need help
I have a 1990 Ford ranger. When going up hills or pulling out fast
it buck's or hesitate's and sometimes it will die. But, I can turn it
around and go up a hill in reverse just fine, with no hesitation's or
any problems at all. I have had a new fuel pump, fuel filter, fuel relay, new plug wire's. I also had a fuel presure test and it showed 40. What could be wrong? Need help, guess work is getting expensive. Thank's.
Old 10-23-02, 07:00 AM
Joe_F
Start with the links and posts in my signature file below.
Old 10-23-02, 04:35 PM
cheese's Avatar
Received 30 Votes on 25 Posts
Check your motor mounts. Pulling off fast, and going uphill puts a strain on the mounts, and if one is letting the engine lift up, then it could be pinching or pulling a wire, causing your problem. In reverse, the engine tries to twist the other way, so it won't lift up on the same side.
Old 10-23-02, 11:17 PM
Good point on the motor mounts. also you may want to do a fuel pressure test while you go up hill and during acceleration. Dont let the fact that you replaced the fuel pump mislead you and that you think its actually doing its job, some of the aftermarket pumps are real garbage. Pressure is one thing and volume is another, both conditions must be met. I have had 2 vehicles on other boards go through 4 pumps apiece before they replaced them with factory pumps. Use and AC Delco/GM or a Motorcraft/Borg Warner. Did you also replace the strainer on the fuel pump? Have you pulled error codes off the computer? You could also have MAP/MAF sensor problems or vacuum leaks.
