thumping...
thumping...
I have a 2000 Pontiac Sunfire 2.2L and I can hear a thumping noise when I turn the steering wheel. It sounds louder when I apply the brakes and it's most noticeable when I'm parking. I took it to get it checked and they looked at the brakes but said the brakes were fine. Do you have any idea what it could be?
Thanks
Thanks
Take it back to the dealership as it should be under warranty and tell them everything you put in your post. I think by what you described you have something loose in the front suspension or steering system (ball joint, tie rod, sway bar link or bushing, etc). Good luck
Sounds like it needs the intermediate shaft lubed. Seen a lot of these. There is a bulletin for this complaint. Dealer has the bulletin and the kit. Should be covered under warranty if under mileage.
I got it into the dealer I bought it from which was a Ford Dealer. They said it's ABS problems and that it needs to go to a Pontiac dealership for the proper machinery. Anybody have ideas what it could be with the ABS before I take it to Pontiac and they start charging?
