Adjusting Clutch
Old 10-28-02, 03:25 PM
R
Richkathy
Question Adjusting Clutch
Can you adjust the clutch on a 1986 Ford Ranger 2.9 If so How is it done
Thanks
Old 10-28-02, 04:20 PM
D
davidf
If the clutch is hydrolic then there is no adjustment.Look for a clutch fluid container like your brake fluid container inside the engine compartment.If it is not hydrolic then turn adjuster nut at the clutch lever near transmission.The lever is an arm on the clutch bell housing that moves the clutch pressure plate when you press the clutch pedal via cable.
