exhaust leak problem
Hi, I replaced a front pipe on my buddy's '94 tercel a while back, but there's still a little hiss coming out of where I bolted the pipe into the manifold. The gasket is fine. Is there a liquid gasket that I can apply to the end of the pipe so it seals to the manifold? I tightened this thing as tight as possible, but it's still hissing!
Thank you
Thank you
