clutch
Old 11-01-02, 03:38 PM
blackjack21
clutch
I HAVE A 1998 CHEV.PICKUP FIVE SPEED. THE CLUTCH WORKS FINE.I JUST HAVE TO MUCH PLAY IN THE PEDEL.HOW DO I AJUST IT?TELL ME ALSO WHAT ARE THE BEST SPARK PLUG FOR THE V6.
Old 11-01-02, 03:50 PM
Joe_F
Kill the caps, no need to shout.
OEM AC Delco plugs are fine for this. Anything else is a waste of money.
On the clutch---see autolibrary as I have it bookmarked below.
Old 11-04-02, 02:46 PM
blackjack21
clutch
ON THE PROBLEM WITH MY CLUTCH WAS;THE TRUCK HAS A HYDRAULIC CLUTCH SYSTEM.IT ALSO HAS A MASTER CYLINDER.WHAT HAPPEN WAS THE FLUID HAD GOT LOW AND AIR GOT INTO THE LINES.WHAT I HAVE GOT TO DO IS BLEED THE AIR OUT OF IT.TO DO THIS YOU NEED HELP.YOU BLEED IT JUST LIKE YOU BLEED BRAKES.THE BLEEDER IS ON THE DRIVERS SIDE OF THE TRANSMISSION.OPEN THE BLEED VALVE;THEN PUMP THE CLUTCH PEDEL HOLD DOWN AND BLEED.DO THIS UNTIL YOU HAVE A FIRM CLUTCH PEDEL.
I HOPE THIS WILL HELP SOMEONE ELSE WITH THIS PROBLEM
Trackbacks are On
Pingbacks are On
Refbacks are On
