Won't Start Now
Old 11-02-02, 07:13 AM
gu812
Won't Start Now
working on 1996 GMC jimmy 4.3ltr engine overheated replaced waterpump.{was leaking} WAS running real rough at an idle, When ilde turned up it runs smooth an has lots of power when taking off. I did a tune up everthing was originalparts. Veh. ran for 20 to 30 then shut down, NOW it wouldn't restart. DIST> is turning I'm not sure if veh. has a timing belt or chain.
THE VEH, has 111,000miles on it
Old 11-02-02, 02:07 PM
Joe_F
Start with the posts and links in my signature file below.
Old 11-02-02, 03:04 PM
the_tow_guy's Avatar
And how badly was it overheated? Are we talking drove it home with the temp gauge needle buried in the red?
Old 11-02-02, 04:29 PM
gu812
Smile RE:WONT START
First of all DONT DO TUNEUPS IN THE RAIN
VEH. STARTED RIGHT AWAY, THOUGH STILL RUNS LIKE CRAP
ENGINE WAS OVERHEATED. I DID A COMPRESSION TEST AN FOUND # 2&4 CYL. WHERE VERY LOW. LEADS TO BELIEVE A HEADGASKET LET GO.OR HAS A CRACKED HEAD.WILL HAVE MACHINE SHOP CHECK IT.
THANX FOR THE HELP GU812
Old 11-03-02, 06:04 AM
Make sure they check for warpage.
