1989 mercury grand marquis
cuphead's Avatar
11-02-02, 01:18 PM   #1
cuphead
Can anyone help. Installing ignition lock cylinder.
Joe_F's Avatar
11-02-02, 01:54 PM   #2
Joe_F
The steering column is clamshelled. Remove the lower shroud.
You should find an area near the lock where you can insert a small rigid wire. The lock will then slide out. Slide in the new one.
Done.
Check autolibrary.org below for more information.
cuphead's Avatar
11-02-02, 04:18 PM   #3
cuphead
Tryed the link it did not help.Having trouble getting switch back in. got a new switch .
Joe_F's Avatar
11-02-02, 09:09 PM   #4
Joe_F
Not doing something right .
I just plugged in the model, and went to "quickfind" It put me to the R&R procedure of the lock (complete with photos and tips). You must cut and paste the link AS I SHOW IT in my signature file below.
The procedure they show is great for this. If you cannot follow that, I suggest you bail out and have it done professionally (the photos they show are about as good as any).
