not able to remove the final bolt in my water pump for removal.
ckelsoe43's Avatar
11-02-02, 03:31 PM   #1
ckelsoe43
I am trying to replace the water pump on my 1991 Buick Park Avenu and cannot get the last bolt out from under the Left Engine mount. Can any one help?!!!!!!!!!!!!!!!
knuckles's Avatar
11-02-02, 07:56 PM   #2
knuckles
I'm not clear on your problem.
Are you having trouble accessing the bolt, or can you access it but it won't turn?
davo's Avatar
11-02-02, 08:33 PM   #3
I believe you need to remove the mount.You will need to jack up the engine to get it out .I f you have the cross brace between your struts(you should)remove it to avoid damage to your p/s pump.
Joe_F's Avatar
11-02-02, 08:57 PM   #4
Joe_F
Check my signature file (autolibary.org) for the water pump R&R procedure as well as what you've been told here.
