'88 Bronco elect. shift control sw
Old 11-05-02, 01:43 PM
tnpops
Hello One and All;
1988 Bronco II, 2.9L, manual trans., Borg-Warner 13-54 transfer case.
I have located the Electric Shift Control Module, speed sensor, motor assy. and shift position sensor. I assume the Electric Shift Control Switch is the console mounted overhead. Are there any more relays located anywhere? i.e under the dash etc.
Thanks for any help.
Old 11-05-02, 03:28 PM
Could you state your problem? It may help.
Old 11-06-02, 11:47 AM
tnpops
4x4, lo range inop
the 4x4 and lo range is inop. when I push either sw. I hear a faint sound like a relay from under the dash, but I cannot locate the source of the sound. I have a Hayes Manuel, but it does not show relay. But another person whose query I read on another site stated there was a relay for the 4x4 and lo-range located under the dash. I was just wondering where this relay is at.
Old 11-06-02, 05:01 PM
Joe_F
Common problem on many Fords is that the shift solenoid brushes get glazed from non use.
Knuckles has published a website URL in the past for this malady.
