1978 f150
pweber's Avatar
11-06-02, 06:11 PM   #1
pweber
1978 f150
Have a F150 2WD with 98K miles. The rear end clunks when I shift to reverse and drive. The universals are good. I've never changed or checked the fluid. Could low fluid cause the problem?
TECHMAN's Avatar
11-06-02, 06:19 PM   #2
TECHMAN
No low fluid will not cause clunking noise in rear end. But --if rear end was run low on fluid it can cause excess wear to bearing, gears and splines in diff. Soun let you may need to pull rear cover for inspection. ---Good Luck-----Dave----
