1995 Mercury Villager Headlight no lowbeam - only high working on one of the headligh
Old 11-11-02, 07:49 PM
jeffsherry
Question 1995 Mercury Villager Headlight no lowbeam - only high working on one of the headligh
Hi. We have a 1995 Mercury Villager. We noticed that the passenger side headlight wasn't working so we bought a new bulb. However, it still wouldn't light up. Subsequently, we found that the same bulb would light up if we put on the high beams but not the normal headlight beams. We switched the bulb and know it's not defective (it worked in the other headlamp for both low and high beams). What else could be wrong? Can we fix this ourselves since we are unemployed for past 8 mos. and trying to save money. Thanks much.
Old 11-12-02, 05:06 AM
Joe_F
If all the bulbs check out, you may have a bad dimmer/multifunction switch in the steering column.
See autolibrary.org below in my signature file to see if they have the R&R procedure and testing procedure.
If it tells you to disarm the airbag, stop here. Seek professional service. You can compromise the integrity of the air bag system if you don't have the proper tools to service it.
Trackbacks are On
Pingbacks are On
Refbacks are On
