Ford T Bird
Old 11-18-02, 04:35 PM
JDIDDY
Ford T Bird
1991 Ford T- Bird/ auto/ a/c 3.8 litre. Idle is too high.
Old 11-18-02, 04:38 PM
Joe_F
Clean the throtttle body with the Ford approved cleaner and if that fails, replace the Idle Air Control Valve.
Old 11-18-02, 05:37 PM
JDIDDY
Thanks Joe, will try per your advice and let the forum know of the outcome.
Old 11-19-02, 12:28 AM
knuckles
You might also want to check for a vacuum leak. In particular, check the vacuum hose to the climate control where it tees off of the intake manifold. The vacuum hose is hard plastic, but there's a short rubber section that connects to the intake manifold. This section is prone to deteriorate & leak, which causes a high idle.
