catalytic converter 88 ford ranger
Old 11-20-02, 08:54 AM
ddanl628
Unhappy catalytic converter 88 ford ranger
i went in for a smog test in CA and the test failed because of the "HC" levels were extremely too high. i was told that this could be caused by the catalytic converter not working. Is this right? is there any way that i can tell if the catalytic converter is working or not?
Thank you.
Old 11-20-02, 09:52 AM
Joe_F
HC is caused by too much unburned fuel going through the exhaust.
You'd have to give us more detail on when the last time the vehicle has seen a maintenance before determing where the fault is. A full tuneup with all filters and parts is a starting point.
Old 11-24-02, 10:19 PM
alton316
I had the same problem with my 88 buick wagon,
failed with really high readings, so i replaced the catalytic convertor, went back for a retest, and passed with really low
readings. so i think it would be safe to say, yes.
change your cat.
Old 11-25-02, 05:40 AM
Joe_F
Thumbs down
NO!!!
Changing the converter without finding the root cause of the reason the first cat failed will grenade the new cat in a heartbeat.
The cause of the poor running/rich mixture must be found and corrected or the new cat will die the same fate!!!!
