1993 Voyager
1993 Voyager
My 1993 Voyager leaks oil & I can't find out where. I changed the valve cover gaskets. 6cyl 3.0ltr. Thanks
Look at the back of the engine .Sometimes the only way to see if it leaks and where, is on a garage lift for those situations where oil leaks are not visible . To pinpoint where it leaks you may have to do an engine cleaning which is best done at a garage.
Oil Leak
Yeah I have a 95 Voyager with a 3.0 in it and it was leaking oil and after changing everything I could think of it ended up being the cam seals. I don't know if this could be it but I was told after I couldn'nt find leak and had replaced a few things by the mechanic that did fix the leak that the 3.0 were bad for cam seal leaks. No problem after he replaced cam seals.
