Differential problems-Chev.astro van
Old 11-22-02, 08:34 PM
Mr.X
I have a whinning noise comming from my right rear wheel.It gets louder as I accelerate,but otherwise runs fine.It's a '97 with 115,000 miles.Could it be a bearing,or the axel,or possibly the ring & pinion gears.How hard is it to replace?What about a junkyard rear end?
Old 11-22-02, 09:14 PM
knuckles
It's probably an axle bearing if you're absolutely sure the noise is coming from the right rear wheel.
The axle bearing & seal are actually very easy to replace. The job requires only common hand tools & the ability to follow directions.
Upon disassembly, you may find a groove worn in to the axle shaft. Use an offset bearing from Green Ball Bearing if your axle is grooved. Otherwise use the standard replacement bearing & seal from GM or any good aftermarket supplier.
Copy & Paste the URL below for axle bearing replacement instructions.
http://www.cybrrpartspro.com/Chilton%20Manuals/8826m/8826CH07_37.HTML
