timeing
hershell waltha's Avatar
11-25-02, 10:15 AM   #1
hershell waltha
timeing
how to hook up timeing light to 91 s10 4.3. i just put in new long block set the piston at top #1 and dis.pointing at #1. it starts and runs good but i am not sure that i'm on the money. sorry i did not tell you more but my first time on this site.i have done this before, a long time ago, lost my inst. book, and cannot find in any shop manual i have. thanks hershell
Joe_F's Avatar
11-25-02, 10:24 AM   #2
Joe_F
See the links in my signature file below. No need to set the timing on a computer controlled vehicle like this. No benefit unless you busted a timing chain.
bejay's Avatar
11-25-02, 05:57 PM   #3
there is a connector that needs to be disconnected before you set timing located on the passenger side floorboard, it is a single wire connector and wire color is tan with black stripe after setting timing to spec 0 degrees plug back in connector.
