automotive
Old 11-25-02, 05:40 PM
junee
automotive
i have 96 accord 4 cycl v-tec engine i'am changing timing belt
need help in the direction to remove the crankshaft pulley is it
clockwise or counterclock wise.
Old 11-25-02, 05:51 PM
if you are referring to crankshaft bolt i believe you remove it as normal which would be counter clockwise when looking at the bolt, you may have to use an impact wrench on it they are usually tight and would be hard to remove by hand.
Old 11-25-02, 07:01 PM
Joe_F
Go to any parts store and rent a puller for the balancer. You will need it. Also, there are tools used to hold the balancer while you remove it.
Old 11-25-02, 10:44 PM
knuckles
The Honda balancer is a slip-fit. No puller is needed. You WILL need a special tool to hold the balancer when removing the bolt if you don't have access to a VERY STRONG impact wrench.
Autozone *may* have this tool in their tool loan program. If not, you can buy one from any tool distributor or you can make one from plumbing fittings if you're handy w/ a welder.
