fan belt 98 Ford
Old 11-26-02, 04:43 AM
Eagle77
fan belt 98 Ford
My alternator on my 98 Ford E250 went. I was able to remove it, and install a new one, but I can't see how to create enough slack on the belt to reinstall. Normally there is a slotted bracket on one of the pulleys for adjusting the tension, but I don't see that anywhere. Does anyone know which pulley is the adjustable one? And is there a special tool for this?
Thank you,
Eagle77
Old 11-26-02, 06:56 AM
Your van would have a spring loaded spring tensioner on it.Alot of times on these vans, they're toward the bottom but i'm not sure on this year model. Just use a wrench or a socket and ratchet to take the tension off the belt.
Old 11-26-02, 06:12 PM
Eagle77
Thanks Fordtech. I found it this morning. I had tried to move it by hand originally, then dismissed it as being the tension pulley. But after using a wrench, I was able to move it.
Thanks again.
Eagle77
Old 11-27-02, 05:46 AM
I'm glad to be of some help.Good luck in your future automotive experiences
