tires
Old 12-01-02, 04:28 PM
P
Received 1 Vote on 1 Post
tires
hello
i have tires and i would like to know who makes them;
the tire itself says regul pace setter.
the receipt says p/185/65r14 regal gt
i've looked every where on my pc with no luck and i'm hoping someone here knows how to look this up or has a book or a tip for me.
thank you
pete
Old 12-01-02, 04:31 PM
Joe_F
They are some offbrand company I believe. If the numbers are OK (treadwear, traction, temperature) then it's probably a decent tire. Compare those ratings versus others in that same range at the tire dealer.
ALWAYS buy by the numbers on tires. Compare the ratings for tires in the same size range and type as you are considering. Cheap tires could cost you your life.
Alternatively, if you e-mail the Tire Council of America (I believe that is what it is called) with some of the # on the sidewall, they may be able to identify them.
Why not just ask where you bought it or look on the sticker that the tire jockey removed? The name is on there .
Old 12-01-02, 04:46 PM
P
tires
hi joe
i'd like to thank you for the advice which i'll take to heart and get moving on first thing.
pete
