fuel,pump- 93 Escort Wagon
Old 12-02-02, 11:51 AM
RichNor
Hi,
Know fuel pump is in gas tank. Is there access through floor in pass compartment, or, do I have to drop tank to change. Also, are there connections on top of tank, that might work loose, that can be tightened from below?
Thx
Old 12-02-02, 07:25 PM
you will have to remove the tank to access the fuel pump, the connector is on top of the tank and usually gives no problems unless previosly broken or installed inproperly, the tank will have to be lowered to access the connector also.
