91' Mustang cold start problems
Old 12-04-02, 05:55 PM
D
dalecm
I have a 91' LX Convertable with the 5.0L engine and manual transmission. It has 115K miles and has seen good care. Recently it won't idle worth a darn on a cold start. I replaced plugs, plug wires, dist. cap and rotor to no avail. Checked the PCV valve and timing. It runs great when warm and starts great when warm also. Any suggestion?
Old 12-04-02, 06:25 PM
D
davidf
Does it have a carb?If so ,choke or hot air stove pipe system is not right.
Old 12-04-02, 10:39 PM
K
knuckles
All Mustangs have been EFI since 1987.
Check your IAT & ECT sensors as well as your idle air control valve.
Old 12-05-02, 05:40 AM
Joe_F
I agree with Knuckles
Old 12-05-02, 08:53 AM
F
fordman30
MUSTANG
My grandma sable was doing the same thing so I put a idle air control valveand it was fix.But, remember to carry your vin# to the dealer so they give you the right one .It is a easy fix 2 bolts out and 1 plug to unplug.10 min tops....have a merry x-mas
Old 12-05-02, 01:49 PM
actually, the 86 gt was the first year for multiport injection and computer, the 85's had the 4bbl holley carb and the roller cam.
Anyway, this is a very very very common problem with mustang 5.0's there was a huge discussion on this here:
http://www.corral.net/forums/showthr...threadid=10805
would suggest checking it out, you can run yourself in circles with this one.
Old 12-06-02, 10:05 AM
Joe_F
Mid 1984 also had fuel injection in the GT350 special edition model that year. Vin M engine as I recall. My former coworker had one.
Also, 1985 manual tranny equipped were Holley 4 barrel, 1985 autos had CFI to my knowledge.
1986 had Bosch MFI as you stated.
The Holley 4 barrels aren't worth 50 cents. Smokers, leakers, fuel wasters. The fuel injection was a vast improvement
Old 12-06-02, 05:18 PM
D
dalecm
Thanks
I appreciate all the suggestions. I'll let you know the results as soon as I have time to dig in to it. Should be able to get to it the week of the 9th .
Thanks again`
Old 12-07-02, 10:00 PM
D
dalecm
What is it?
Is the idle air control valve the same thing that the Chiltons manual call the Air Bypass Valve?
Old 12-07-02, 10:16 PM
Joe_F
Yes. The bypass term is Ford terminology.
Old 12-08-02, 12:26 AM
If you replace the valve you may need the part number off the old one. Take it with you to the parts store.
Old 12-08-02, 06:00 PM
Joe_F
Thumbs up
Stevo is correct. It will also help the dealer find it quicker too.
Old 12-08-02, 09:23 PM
H
I had the same thing happen to my 1990 Ford with a 5.0L engine. Not knowing much about EFI, I brought it to the local Ford dealer, who replaced the air bypass valve and that solved the problem. However, I was not too happy after I found out what that valve is and where it is located, because the dealer charged me $ 265 for labor to replace it and $94 for the valve!
Old 12-20-02, 08:29 AM
D
dalecm
Thumbs up Resolution
Well......I finally got the correct part after three trips to the local auto parts store. It did take about five minutes to replace and I paid about $75 for the part. Cold starts are about 95% better. The idle seems a little low, but it runs when cold without having to work the gas pedal constantly.
Thanks everyone
Old 12-20-02, 08:36 AM
F
fordman30
Did the idle air control valve fix the problem ? And you are very welcome...Have a Merry Christmas and New Year
Old 12-20-02, 08:52 AM
D
dalecm
Yes it was the idle air control valve. Sorry I didn't include that info.
Thanks again
