12-04-02, 07:45 PM
jeff1
Hi all,
Joe F keeps telling me to come over and ask an auto question....so here it is.....
1993 Chevrolet Beretta, my boys car. Engine size unknown, but it is a 6 cyclinder, automatic.
Drivers side wiper blade and arm wouldn't move after recent snow fall, passenger side worked ok. I opened the hood and removed small plastic cover and found the wiper arm nut loose....I tightened bolt/nut and the wiper worked but they hit one another
So I loosened the nut again and moved wiper arm up towards the roof a little bit and re-tightened the nut/bolt....now the blades no longer hit one another
Should I be worried as to why the nut/bolt became loose in the first place?....maybe jammed on ice/snow?...should I have used loc-tight? ( or the Mrs nail polish ) on that bolt/nut. Winter is here already in the Great White North and I don't want them ( my boys ) out and have this thing quiting on them!!
TIA,
jeff.
TIA,
jeff.
12-04-02, 10:34 PM
knuckles
It likely worked loose from normal use, but it could've been due to the ice.
Not something to worry about. You can use medium strength Loctite on it if you want.
12-05-02, 05:36 AM
Joe_F
Sorry I didn't get to you sooner Jeff
Knuckles is right. Make sure the blade is on the serrated part of the arm squarely.
Tighten it and put some Loctite on it....it will be fine. They can work themselves loose.
I have had the linkage arm come off for no reason. Tightening it usually rectifies it.
12-05-02, 07:20 AM
Joe_F
FYI: The likely engine size in this Beretta is a 3.1 liter vin code M engine (8th digit of the Vin # is an M)
Doesn't matter in the case of this question
Hope it's fixed
Hope it's fixed
12-05-02, 03:47 PM
jeff1
**The likely engine size in this Beretta is a 3.1 liter**
Thankx Joe....that is the correct size....goes like hell!!
**Doesn't matter in the case of this question**
I didn't think so either....but I read your "what info to have" before posting message....
jeff.
jeff.
12-05-02, 07:36 PM
Joe_F
Jeff:
You're welcome, any time, and glad we could help.
Feel free to come by anytime.
