ac and heater no ac no heater f150 pickup
martymatty's Avatar
12-06-02, 02:32 PM   #1
martymatty
ac compresser went out . when heater is turned on it kick in and stalls motor. need heater can do without ac. can i just change the belt "go around ac pump" the diagarm is there . someone said i would have to change pulleys. can i just take the fuse out of ac and run heater??? thank you merry xmas
fordtech's Avatar
12-06-02, 05:01 PM   #2
Just unplug the a/c compressor.
Joe_F's Avatar
12-07-02, 06:11 AM   #3
Joe_F
Unplug it for now, but fix it in the long term.
The defroster uses the A/C compressor to help defrost and dehumdify the windows .
roland1978's Avatar
12-08-02, 02:48 PM   #4
roland1978
The defrost will still work. Had to bypass ac on mother inlaws taurus two years ago and her defrost works fine in the winter.
Joe_F's Avatar
12-08-02, 05:36 PM   #5
Joe_F
It will "work", but not correctly.
Again, defrosting cycles the A/C compressor to dehumidify as well as defrost.
