cv half shaft
Old 12-11-02, 08:24 PM
greaser45
cv half shaft
hello,
I am working on a 93 honda prelude. I need to pull the CV half shafts in order to pull the engine out. there are no bolts holding it on except the one on the wheel hub, how do I remove the CV half shaft from the engine. any insight would help thank you
Old 12-11-02, 08:32 PM
most just pop out of the transmission using a pry bar it has a small wire reatiner clip holding it in, you will have to seperate ball joint to allow enough clearance to remove shaft from hub and then from transmission. you might check the link below for more information.
http://www.cybrrpartspro.com/Manual%...delLookup.html
