check engine light
Old 12-11-02, 10:38 PM
bloodyknuckles
check engine light
I am looking for any reasons as to why this light keeps coming on, obvious or not. any ideas? it is a late yr 95 Grand Am.
Old 12-11-02, 10:59 PM
knuckles
Take it to Autozone & let them scan the PCM for trouble codes. Record the codes & post them here. We'll tell you what they mean & their possible causes.
Old 12-12-02, 08:51 AM
bloodyknuckles
thanks for the input, but I already tried that. Apparently since I have the late yr 95, it is the "rare" one, the one with a different numbered pin connector. according to them, the only way i can get it tstd is to take to the dealer, or another qualified mechanic which equals $$$. I was just looking for a few common areas to check. I will take it to a mech. if I have no other option. My only concern is that since I drive approx 45 min to and from work everyday, I want it to be dependable.
Old 12-12-02, 10:50 AM
Joe_F
Choose another Autozone that has an OBDII scanner available and can scan the codes.
You probably have an early OBDII model and this particular store didn't have the right scanner/connectors for it.
Old 12-14-02, 11:23 PM
1fireman
Just some food for thought.
The check engine light may come on because of a bad sensor.
When I installed a K&N filter in my car I forgot to reconnect the wire to the mass air flow sensor, causing the check engine light to come on, which would be similar to the sensor going out.
Old 12-14-02, 11:39 PM
knuckles
It might also have come on due to any number of other problems. We won't know until the PCM is scanned for trouble codes.
Old 12-15-02, 07:25 PM
I
bloodyknuckles your car is not OBD-II, that didn't start until '96, for the most part anyway. Go to
http://www.cybrrpartspro.com/Manual%...delLookup.html
which is what Joe_F usually recommends. You're in luck, they have a LOT of info on your car. Even tells you how to retrieve the code.
Ichabod
Old 12-15-02, 10:37 PM
knuckles
The '95 Grand Am is not OBD-II, but it still requires a scan tool for DTC retrieval.
It uses the old style 12 pin diagnostic terminal, but the "B" slot is empty, so you can't use a jumper wire to retrieve codes.
Old 12-16-02, 11:59 AM
Joe_F
Thumbs up
Knuckles is correct.
Old 01-29-03, 08:39 AM
absutton
check engine light
If you want to find out your trouble codes without spending a ton of $$$, just get your emissions checked for $25 and they will tell you the codes on the report.
Old 01-29-03, 10:40 AM
Joe_F
True, but why? Autozone does it for free. Why have a failure report in the state's computer (not all states can tell you why it's on) to draw attention to your problem?
