'84 Chevy S-10 Factory Tach
Old 12-16-02, 04:38 PM
L
LAWLES
I recently located a factory dash for my S-10 blazer with a factory installed Tachometer. The tach works well with the currently installed 2.8L V-6. I am in the process of converting to a V-8 with an HEI or Mallory Unilite distributor. Does anyone have a wiring diagram or schematic for this tach or know what adjustments need to be made to this tach for use with the V-8?
Old 12-16-02, 06:34 PM
B
more than likely you will have to install a universal tach, the tach runs from the negative side of the coil and i doubt the factory tach had any switch for 4,6,or8 cylinders like an aftermarket one would which means if factory tach is used it will not be accurate,
you might be able to find the same style tach on a full size v-8 pickup that could be switched to your instrument cluster dont know for sure though.
Old 12-16-02, 07:23 PM
Joe_F
I agree with BeJay.
Old 12-16-02, 11:04 PM
K
knuckles
Arrow
I suggest you check http://www.jagsthatrun.com . The OEM tach can be recalibrated to work w/ a V-8 & JTR has the info you need for other aspects of the V-8 swap as well.
