High Idle on '90 GMC Van
69camaro's Avatar
12-18-02, 01:30 PM   #1
69camaro
'90 GMC Safari Mini Van V-6, 100,000 miles on van. Van idles high (2,000 rpm) and will only return to regular idle (around 900) if you tap the accelerator pedal while in neutral or park. Pedal & linkage are not binding, complete tune-up 3 months ago (inlcuded new plugs, new wires, pcv, air filter, fuel filter, O2 sensor, EGR, EGR Solenoid, Map Sensor, pick up wires, rotor & cap). Just started a couple of days ago. No active or stored codes. Help?
Joe_F's Avatar
12-18-02, 02:45 PM   #2
Joe_F
Check the throttle body unit for loose bolts or a squished gasket...common problem.
Spray a little carb. cleaner around the TBI base/manifold and if the idle races/picks up, your problem is a loose TB or bad gasket.
A couple of bucks at any parts store.
davo's Avatar
12-18-02, 04:26 PM   #3
Iagree with Joe check the gasket close seen alot of them leak.Maybe the idle air control valve is starting to go bad.
