rear view mirror
Old 12-20-02, 07:50 AM
jjerry99
rear view mirror
What type of adhesive should be used to reattach a mirror to a windshield
Old 12-20-02, 10:28 AM
Y
rear view mirror glue
check the auto store
Old 12-20-02, 10:29 AM
the_tow_guy's Avatar
Received 43 Votes on 35 Posts
There are a couple of specialty type adhesives for the job. Check at any good auto parts store.
I've used plain super glue fairly successfully a couple of times as well. The trick in all cases is to make sure both the glass and the attaching point are properly cleaned.
Old 12-20-02, 11:33 AM
Joe_F
It can be tricky to do and frustrating.
You might also seek the help of glass shop in the area. Most don't charge much to do it.
Old 12-20-02, 08:20 PM
K
knuckles
Clean both the glass & the metal mirror mount.
Make sure you remove the mirror mount from the mirror! It's typically held to the mirror with a Phillips head or Allen head set screw. Some 1991-up Ford products retain the mirror with a spring clip.
There's a slot on the mirror housing on these cars that allows you to slip a small flat blade screwdriver in to release the spring clip tension.
After the mirror mount is removed from the mirror & clean, prime the mirror with the primer/cleaner provided in the adhesive kit. Be sure to prime the glass as well.
Place 1 drop of adhesive in the center of the mirror mount & apply the mount to the glass. Hold the mount in place for about 30 seconds-1 min. to allow the glue to set.
Wait at least 1/2 hour before installing the mirror.
Old 12-20-02, 08:53 PM
R
roland1978
Be sure to use only one drop of glue,any more and the mirror will fall off again.
Old 12-20-02, 10:54 PM
D
It's helpful to mark the location of the mount area on the outside of the windshield, with a crayon, prior to cleaning the old glue off. It will show you proper location when you go to glue up mount.
